Finchy's Manx
Re: Finchy's Manx
Postby finchy » Thu Feb 02, 2012 7:03 pm
OK time for front end build, bottom ball joints well lets say I was lucky. I will be doing the hole front end bar steering box. Half pulled apart so far.
front end 004.JPG (69.58 KiB) Viewed 5432 times
front end 003.JPG (71.25 KiB) Viewed 5432 times
front end 001.JPG (118.5 KiB) Viewed 5432 times
Re: Finchy's Manx
Postby Tratty » Sat Feb 04, 2012 8:01 am
Finchy that is definitely a ball joint front end, you could use 181, but if you wanted to stay stock I could probably help you out. :D. But I wouldn't throw those old arms out, you could get them spray welded and reground.
Re: Finchy's Manx
Postby finchy » Sat Feb 04, 2012 9:40 am
Yeah unsure what to do but I am interested on how to tackle inner bush ?
Re: Finchy's Manx
Postby Tratty » Sat Feb 04, 2012 9:46 pm
I would make a small slide hammer, a piece of steel on the end to bridge the bush with a very sloppy hole for the rod, so you can push it up diagonally though the bush, then you are on your own best of luck :)
Re: Finchy's Manx
Postby finchy » Sun Feb 12, 2012 7:37 pm
Ok today I made 2 slide hammers, 1 for top & 1 for bottom, nothing is ever easy. (Different size bearings) Pulled outer bearings out no probs, Pulled inner bushes out no probs, rrr maybe a few words.
Interesting bearing has got like a felt or plastic attached. 2 piece inner bush
2011-04-02 002 005.JPG (44.92 KiB) Viewed 5330 times
2011-04-02 002 004.JPG (55.63 KiB) Viewed 5330 times
Re: Finchy's Manx
Postby finchy » Sun Feb 12, 2012 7:43 pm
Ready for new bits $$$
2011-04-02 002 002.JPG (83.47 KiB) Viewed 5329 times
Re: Finchy's Manx
Postby Tratty » Sun Feb 12, 2012 11:07 pm
Good to see you got them out :D
Re: Finchy's Manx
Postby finchy » Tue Feb 14, 2012 5:28 pm
Ok after checking out a lot of torsion arms I found some good S/Hand arms from Rodger at southside vw. I gave them a bit of a clean and pressed in some new ball joints.
Me Happy Jan
2011-04-02 002 004.JPG (77.18 KiB) Viewed 5291 times
then a bit of a paint
2011-04-02 002 003.JPG (76.74 KiB) Viewed 5291 times
2011-04-02 002 001.JPG (92.47 KiB) Viewed 5291 times
2011-04-02 002 002.JPG (87.53 KiB) Viewed 5291 times
Re: Finchy's Manx
Postby finchy » Thu Feb 23, 2012 6:30 pm
Beam was getting a bit scruffy so got it sand blasted + 2pac primed. Then super etched and epoxy enamal
2011-04-02 003 003.JPG (78.47 KiB) Viewed 5225 times
2011-04-02 003 001.JPG (80.82 KiB) Viewed 5225 times
Re: Finchy's Manx
Postby finchy » Thu Feb 23, 2012 6:40 pm
New teflon bushes, bearings & seals installed.
Torsion arms fitted
2011-04-02 003 011.JPG (81.64 KiB) Viewed 5225 times
2011-04-02 003 004.JPG (68.94 KiB) Viewed 5225 times
2011-04-02 003 007.JPG (49.11 KiB) Viewed 5225 times
Mackaybaja
Re: Finchy's Manx
Postby Mackaybaja » Thu Feb 23, 2012 9:12 pm
Looking real nice Shaun. :mrgreen:
Re: Finchy's Manx
Postby finchy » Thu Feb 23, 2012 9:43 pm
Mackaybaja wrote:Looking real nice Shaun. :mrgreen:
yeah alot more work than it looks, getting inner bushes in with out damage took a bit, but all good.
Re: Finchy's Manx
Postby finchy » Sat Mar 24, 2012 6:58 am
Front adjusters were open to the elements so I made up some dust covers
buggy tunnel 039.JPG (62.33 KiB) Viewed 5106 times
buggy tunnel 038.JPG (64.88 KiB) Viewed 5106 times
Re: Finchy's Manx
Postby finchy » Sat Mar 24, 2012 7:47 am
Inspected Tunnel and Frame head, after all these years I was pleasantly surprised. Go the Gal
buggy tunnel 055.JPG (84.09 KiB) Viewed 5104 times
buggy tunnel 044.JPG (74.52 KiB) Viewed 5104 times
Re: Finchy's Manx
Postby Tratty » Sat Mar 24, 2012 10:15 am
Nice work Finchy :D
