Finchy's Manx
Re: Finchy's Manx
Postby finchy » Sun Apr 01, 2012 6:51 pm
Well on the way home today on Northshore my gearbox decided to develop a knock, I was not sure if I would make it home. 250-300 klm
I did make it but only just, It got to the point that any bit of gas on I thought it would let go. The last 15 klms was very touch n go whether it would make it home.
BAJAKOMBI
Re: Finchy's Manx
Postby BAJAKOMBI » Sun Apr 01, 2012 7:28 pm
Good too see you made it finchy. No other car would of with that sort of noise coming out of it.
Re: Finchy's Manx
Postby VWNuts » Mon Apr 02, 2012 10:15 am
After seeing the flogging you gave it at Stockton I'm not surprised, but you did say you've been driving that way for the last 15 years, so I think you got your money's worth. Good to hear you made it home
Re: Finchy's Manx
Postby finchy » Mon Apr 02, 2012 3:47 pm
VWNuts wrote:After seeing the flogging you gave it at Stockton I'm not surprised, but you did say you've been driving that way for the last 15 years, so I think you got your money's worth. Good to hear you made it home
That box got built when engine was built, yeah about 15 years ago. but has had 1 rebuild since. 15 yrs but only 13 000 klms so 6500 hard klms per build. Still happy but
Re: Finchy's Manx
Postby manxiberty » Mon Apr 02, 2012 6:07 pm
what sort of box you chasing then...someone here may have something...?
Re: Finchy's Manx
Postby finchy » Mon Apr 02, 2012 8:22 pm
manxiberty wrote:what sort of box you chasing then...someone here may have something...?
I just going to take it apart first and have a look see if its reparable. Has anyone got a detailed book on these gearboxes, that be a good start. I kinda like this one. Its a different problem than the last 2 times.
Re: Finchy's Manx
Postby finchy » Fri Apr 06, 2012 10:16 pm
Good Friday pfft, Pulled engine & Gearbox out today. Drained oil and bang a piece of tooth on drain plug, so for those who picked it, pfft aswell. :lol: If I get a chance I will try pull box apart to inspect.
Re: Finchy's Manx
Postby finchy » Sat Apr 07, 2012 6:58 pm
Ok I pulled box apart today and all gears are good, Pinion gear, well lets say a bit of tooth decay. 1 complete tooth gone and 2 halves gone. will take a photo and post in morning. So all in all I think good news.
Re: Finchy's Manx
Postby VWNuts » Sat Apr 07, 2012 7:12 pm
How do you figure thats good news??
Mackaybaja
Re: Finchy's Manx
Postby Mackaybaja » Sat Apr 07, 2012 7:37 pm
Very lucky to get home Shaun. Just have to find the right ratio now. I got parinoid on the way home thought it was getting noisy so i drained the trany oil but all apears ok. :o
Re: Finchy's Manx
Postby finchy » Sat Apr 07, 2012 10:03 pm
VWNuts wrote:How do you figure thats good news??
I should say better than expected, all the gears 1,2,3,4 have no damage (from broken pinion gear floting around) spider gears no damage, crown has some damage but can grind high spots if cant find replacement.
I honestly expected the box and housing to be stuffed from the knocking that came out of it.
Reverse gear a bit scored on the ends of the teeth but thats from me not picking 2nd at times.
Re: Finchy's Manx
Postby finchy » Sat Apr 07, 2012 10:10 pm
Mackaybaja wrote:Very lucky to get home Shaun. Just have to find the right ratio now. I got parinoid on the way home thought it was getting noisy so i drained the trany oil but all apears ok. :o
Yes the last few klms home was a bit plain to say the least. Kieth I would like to keep same ratio 4.125 , dont have one in your back pocket ha. I think its out of 69/70 irs beetle. Do you know if the automatic beetle use same crown & pinion because I read that is also the same ratio.
Mackaybaja
Re: Finchy's Manx
Postby Mackaybaja » Sun Apr 08, 2012 6:32 am
I will see what we have up here today or tomorow and find out what fits what.
Re: Finchy's Manx
Postby finchy » Sun Apr 08, 2012 7:21 am
well here it is
2011-04-02 004 003.JPG (71.65 KiB) Viewed 5906 times
2011-04-02 004 002.JPG (75.23 KiB) Viewed 5906 times
Re: Finchy's Manx
Postby manxiberty » Sun Apr 08, 2012 7:24 am
just turn it over ......the rest of it looks alright :lol:
