AS0030 - Graham - Baja Bug
Postby VWNuts » Thu Nov 27, 2008 12:00 am
Name - Graham
Manx Club Number AS0030
Location Brisbane, Australia
Buggy Type - Cheetah Baja Bug
Current Buggy Status - Lots of pieces....
Re: AS0030 - Graham - Baja Bug
Postby VWNuts » Mon Dec 15, 2008 1:55 am
Since we no longer have the Baja Bus, we need something for the family got go camping in. So the plan is to have the Manx and this Baja to go away in. With the trailer for the camping gear we should be able to take all the stuff we used to fit into the Baja Bus.
I got the Baja as a rolling concern, but have decided on a full ground up rebuild because that way I can know everythings safe for our daughter to drive it when she gets her learner's next year.
That way I also get to add all the cool stuff I've collected......
Postby VWNuts » Mon Dec 15, 2008 1:59 am
I pulled out the pedal assembly and found the clutch hook looked like this....
Pretty dodgy repair, so I set about fixing it properly, here's a cardboard template of how the hook should look
And in metal
Postby VWNuts » Mon Dec 15, 2008 2:02 am
The rear brakes were Type3, but in need of fixing, so I decided to convert to rear disc brakes from a VN Commodore
Postby VWNuts » Mon Dec 15, 2008 2:04 am
This is when the project started to get interesting...... I picked up some extra bits....
Postby VWNuts » Mon Dec 15, 2008 2:08 am
Since I needed to take the body off the floorpan to fit the Rollcage & Lift Kit, I decided I may as well convert the swingaxle floorpan to IRS, but then Brad told me he had an IRS chassis buried out in his back yard.
So I dragged it home and set about cleaning it up and painting it.
Its a superbug pan that has had a balljoint frame head welded on.
Postby VWNuts » Mon Dec 15, 2008 2:11 am
Now that I have IRS and a lift kit, I can install a Kombi Gearbox and my Type4 2L engine... I'll also be converting to a hydraulic clutch using factory T3 bits
OBU991
Postby OBU991 » Mon Dec 15, 2008 3:47 am
VWNuts wrote:Since we no longer have the Baja Bus, we need something for the family got go camping in. So the plan is to have the Manx and this Baja to go away in. With the trailer for the camping gear we should be able to take all the stuff we used to fit into the Baja Bus.
OMG! your daughter will be old enough to drive next year
Postby VWNuts » Mon Dec 15, 2008 4:03 am
Yep scary huh?!?!
Postby Brad » Mon Dec 15, 2008 4:37 am
wow u are getting old :lol:
MarkMark
Postby MarkMark » Tue Dec 16, 2008 5:04 pm
VWNuts wrote:Since I needed to take the body off the floorpan to fit the Rollcage & Lift Kit, I decided I may as well convert the swingaxle floorpan to IRS, but then Brad told me he had an IRS chassis buried out in his back yard.
Does the Baja have rego already? Or are you planning to re-register it?
Postby VWNuts » Wed Dec 17, 2008 12:26 am
No rego yet, so I'll need to get everything Blueplated when I'm done.
Postby VWNuts » Wed Dec 17, 2008 12:27 am
Brad wrote:wow u are getting old :lol:
I dont think I'm much older than you Brad.... just started earlier.... :lol:
Postby wallace » Thu Jul 12, 2012 9:57 pm
Is this baja still around nuts? Or is this the one you've just finished building and took to Fraser?
Postby VWNuts » Fri Jul 13, 2012 10:32 am
Nah, this one ended up out Ipswich way a while back. The blue one we took to Fraser is the one 68Baja used to own
