MIN76 - Mick Subaru Powered Max FX
MIN76
Re: MIN76 - Mick Subaru Powered Max FX
Postby MIN76 » Tue Sep 21, 2010 6:16 am
Yeah it hangs out there. I didn`t want to cut the bonnet and the budget would not allow a custom radiator. I hope to change it down the track with something smaller or relocate it.
MIN76
Postby MIN76 » Tue Sep 21, 2010 6:27 am
Well heres whats hapened so far. Front end is done, bonnet , screen, bar and lights.
MIN76
Postby MIN76 » Tue Sep 21, 2010 6:37 am
Now onto the engine. Got the intake fitted up, it just needs a few adjustments to clamp it down. Runnig out of room under there now. Thats another thing ticked off the to do list.
MIN76
Postby MIN76 » Tue Sep 21, 2010 6:38 am
Fitted in place.
MIN76
Postby MIN76 » Tue Sep 21, 2010 6:39 am
Not much room left now.
MIN76
Postby MIN76 » Tue Sep 21, 2010 6:50 am
The TO DO list is now as follows.
mount radiator overflow
paint and clamp on intake
mount oil pressure switch
bleed brakes again
bleed radiator
go over whole car make sure i have used 2500 cable ties and everything is tight.
then DRIVE DRIVE DRIVE.
Postby wallace » Tue Sep 21, 2010 7:27 am
Looks good Mick.. Good progress..
Postby Brad » Tue Sep 21, 2010 3:19 pm
MIN76 wrote:The TO DO list is now as follows.
bleed brakes again
bleed radiator
You forgot a few things on your list
Take photos and post updates
Come over so we can make a bigger wiring box
Smile lots :roll:
Postby Lovebuggy » Wed Sep 22, 2010 2:19 am
So this thing should be done by the weekend. :D
Postby Brad » Wed Sep 22, 2010 4:51 am
Lovebuggy wrote:So this thing should be done by the weekend. :D
Pfffft with all this rain I reckon he should be done before that :roll:
MIN76
Postby MIN76 » Wed Sep 22, 2010 8:06 am
Well here`s what got done today. First thing had to drop the coffee machine in to get repaired - most important job. Then started on the buggy, had to fab a bracket to hold the afm to stop it bouncing round.
MIN76
Postby MIN76 » Wed Sep 22, 2010 8:07 am
Who needs a folder when ya got a set up like this.
MIN76
Postby MIN76 » Wed Sep 22, 2010 8:12 am
Bracket done. Didn`t paint it as i am going to put a brace on, should strengthen it up.
MIN76
Postby MIN76 » Wed Sep 22, 2010 8:17 am
Gave the intake a coat of paint and bolted it all up. Also mounted the oil pressure switch and tidys up some of the wiring around the back of the motor. Tomorrow is the radiator overflow and also adj the clutch, which i forgot about. I can almost feel the the wind battered face again.
Postby Brad » Thu Sep 23, 2010 5:14 am
sweet looks good
