Scott's Supa Sports
If you are building a buggy or Baja then please post in here and share your experinces with us
Re: Scott's Supa Sports
Postby VWNuts » Tue Dec 07, 2010 3:10 am
Most of the old Baja Bugs living on Moreton Island have those aircraft tyres
Postby Brad » Tue Dec 07, 2010 5:54 am
Smiley wrote:
Brad wrote:heheh well the one you are working on needs it shock towers modified.
Got any pictures/tech on how to do this?
It's not too late to convince him to go to a super pan :twisted: I have basically down nothing to this one so far.
Smiley :cool:
Rear shock towers on an Early pan with IRS fitted.
If you look you will see where the arm has been hitting the tower in the vicinity of the brake line / upper arm seam. This is due to the shape of the shock tower.
If you compare this to the later factory IRS setup then you will see it has a lot more clearance.
To modify it I usually add a gusset to the area.
Then cut it to clear and flat plate the bottom.
I don't have a picture of it finished and from memory this was Troy's Old Floor pan back a few years pre V6 and this was cut Friday arvo before a beach trip because his trailing arms where hitting.
Smiley
Postby Smiley » Tue Dec 07, 2010 1:52 pm
Ok Thanks Brad.
I'll get Scott to jump on here and have a look and see what he thinks.
Are there any tips/tricks/special procedures for welding the cast shock towers?
Smiley :cool:
Postby Brad » Tue Dec 07, 2010 4:43 pm
Smiley wrote:Ok Thanks Brad.
Smiley :cool:
Hi,
Nah you will be fine, just make sure you clean them unlike those one Troy did :roll:
Return to “Buggy & Baja Building”
Users browsing this forum: No registered users and 3 guests
