kombi suspension into baja
ernie norley
Postby ernie norley » Fri Oct 14, 2011 7:40 pm
Gday all pics of donar modified kombi front & kombi rear mounted insitu the 1/4 panel was to check clearance on kombi chassis members The 1600 kombi box will mount onto tube xmember under motor instead of vw mounts
Re: kombi suspension into baja
Postby Brad » Sat Oct 22, 2011 9:50 pm
Ok I have to ask .. WHY would you want to do this and what are you trying to gain ?
I have seen it done a few times and the results have never justified the effort or weight gain.
Don't get me wrong I am all for doing stuff different but I would just like to know what the motivation for it is ...
ernie norley
Postby ernie norley » Mon Oct 24, 2011 7:00 pm
Gday Brad. Just somthing I have decided to try for floor lift not body the front end has an adjuster set on it for height changes. I had the bits so thought have ago if its no good i will just drop it back onto original pan & turn pan into a ride mower
Ernie
