syncro converting to all subi running gear
ernie norley
Postby ernie norley » Tue Dec 06, 2011 7:57 pm
Gday all. Big day today started conversion on syncro setting it up to run ej20 & reverse subi box & diff we have the front diff sorted out should be mounted tomorrow. the dummy engine & box are in situ the mounts will be pretty straight forward. will start to post pics if anyone is interested in them.
Ernie
mackaymanx
Re: syncro
Postby mackaymanx » Tue Dec 06, 2011 8:01 pm
Because the output to the front diff is high on the gearbox did you section the crossmember to get clearance?
ernie norley
Re: syncro
Postby ernie norley » Tue Dec 06, 2011 8:19 pm
Gday Mackaymanx. No looking at it for an hour or so moving motor up down in out it looks like we wi have about 2 cms clearance we have a syncro already fitted with an ej20 so we are setting motor to its height & it seems to give that much. the front diff we turned upside down & turned rear cover over so drain plugs are at bottom. What Iam looking for if anyone has an idea is some form of dog box 1 to 1 to use in tailshaft as a decoupler type setup.
Ernie
ttriebler
Re: syncro
Postby ttriebler » Tue Dec 06, 2011 9:51 pm
Hey Ernie the really early Subie boxes (EA I think) had selectable 4wd in the center diff housing.
It may be possible to adapt that setup to the Syncro project...but I don't know why anyone would do it.
Millions of Subarus around the world with constant all wheel drive - they seem to get good fuel economy and go forever with their stock setup. I reckon the decoupler is old skool technology that has little merit in a modern drivetrain.
www.subarugears.com
ernie norley
Re: syncro
Postby ernie norley » Wed Dec 07, 2011 6:35 am
Gday All thats what Iam trying to covince the owner of. he had a decoupler fitted to sncro box & believes he needs it on subi. I just have to sort out fitting it after that he can do what pleases him. but I think once he drives it he will change hie mind
Ernie
