DD's Buggy Build
Fossil
Re: DD's Buggy Build
Postby Fossil » Thu Apr 23, 2009 1:52 pm
if you bring the shift position back does it interfere with the handbrake?, or does the handbrake handle need to be shortened also?
Postby Lovebuggy » Thu Apr 23, 2009 2:10 pm
My understanding is that you do not need to move the shifter back on BJ floor pans. This is a mod only made on K&L pans.
MarkMark
Postby MarkMark » Thu Apr 23, 2009 3:18 pm
If you bring the shifter back, then you will need to shorten the hand brake lever. A superbug pan is like this already.
Postby VWNuts » Thu Apr 23, 2009 10:51 pm
Yes the shifter mod is only needed on the link pin pans.
Here's a pic of an original length handbrake lever next to the one I cut down when I moved the shifter back.
Fossil
Postby Fossil » Fri Apr 24, 2009 3:24 am
I knew i wasn't going stupid. OK well maybe i am but thats another story.
But i didn't think that Dan would have to move the shifter.
Postby DDWR450F » Fri Apr 24, 2009 4:03 am
Thanks guys i was about to start cutting!!
Postby DDWR450F » Wed May 06, 2009 4:47 am
More progress pics of the chassis & pan halves
being welded. Where all the spot welds were (forks and neck), they
have now been tig welded.
Postby DDWR450F » Wed May 06, 2009 5:03 am
More
Postby DDWR450F » Wed May 06, 2009 5:13 am
I cleaned up the 2nd hand lift kit i bought from
Mike, took to it with the wire brush and flap disk
came up tops!
OBU991
Postby OBU991 » Wed May 06, 2009 2:31 pm
Nice neat work Dan, looking really good
Buggy Nut
Postby VWNuts » Wed May 06, 2009 11:18 pm
Looking good
Fossil
Postby Fossil » Thu May 07, 2009 5:48 am
And to think this is the first time you've built a buggy Dan.
Your work is Awsome.
Wanna build me a swb pan? :D
Postby DDWR450F » Thu May 07, 2009 8:11 pm
Ha ha Jace, its a long way from being able
to take it over the dunes n go for a surf!
Postby DDWR450F » Wed May 13, 2009 11:21 pm
A few more pics of the build, stripping the
irs bits and the front beam getting preped for painting.
Postby DDWR450F » Wed May 13, 2009 11:27 pm
couple more
Users browsing this forum: No registered users and 6 guests
