Replacing Starter Bush
If it makes power or helps it get to the wheels this is where it is at
Postby VWNuts » Sun Apr 02, 2017 3:30 pm
If you want to replace your starter bush without having to remove your engine, here's the easy way.
I removed the starter motor and found a tap that would thread into the old starter bush
Wind the tap all the way into the starter bush until it bottoms out on the back of the engine case. Keep turning the tap, and it becomes a puller and the bush pulls out of the gearbox with ease.
Then put your new bush on the end of your finger
Fill it with oil
And then squeeze between your thumb and finger. This forces the oil through the bush to keep it lubricated
I then use a bolt and nut that is wider than the bush to tap it back into the gearbox
And tap it into place with a hammer
And then the starter motor is ready to be reinstalled
Re: Replacing Starter Bush
Postby BlueV2 » Mon Apr 10, 2017 4:32 pm
That is pretty cool, not that I have ever had to do it. Thanks for sharing Nuts.
Return to “Engine and Driveline”
Users browsing this forum: No registered users and 5 guests
