1800 5 rib box question.
Postby bajabone » Wed May 16, 2012 9:45 pm
Is the 5 rib bus box genuinely stronger than the 3 rib or just the higher ratio's ?
I like 3 rib ratios with the big tyres on the baja but have access to a 5 rib when I get more hp in the back !
BAJAKOMBI
Re: 1800 5 rib box question.
Postby BAJAKOMBI » Thu May 24, 2012 6:06 pm
bajabone wrote:Is the 5 rib bus box genuinely stronger than the 3 rib or just the higher ratio's ?
They are all only as strong as the weak link ( REVERSE !!!!!!!!!!!!). But i run a 5rib in the kombi . It's still low enough geared for my tank so in a light baja i think it would be good.
Postby Smiley » Thu May 24, 2012 8:34 pm
Hey Shane.
I'm fairly sure that for the most part the boxes are pretty much identical in strength.
The 1800 has a slightly beefier case but the internals will handle the same punishment that a 1600 box will.
I have found the 1800 ratios great for a daily Baja. They are low enough to allow you to crawl pretty well offroad. But high enough that the engine isn't screaming its head off at highway pace.
