Ej
If it makes power or helps it get to the wheels this is where it is at
shane2610
Ej
Postby shane2610 » Wed May 28, 2014 9:18 pm
Hi my ej sometimes idle high and then it slowly comes down to idle ?. Can any body help cheers shane .
mackaymanx
Re: Ej
Postby mackaymanx » Wed May 28, 2014 9:36 pm
Try cleaning the idle valve with some carby cleaner. Also check for a stiff accelerator cable.
shane2610
Re: Ej
Postby shane2610 » Wed May 28, 2014 9:41 pm
Yea mate tried that but still does it ! But it ony does some times not all the time,cheers Shane.
Re: Ej
Postby manxiberty » Thu May 29, 2014 5:55 am
idle control valve works with two butterflies - one is much like a thermostat in that it uses coolant temp to moderate where it is sitting then the other butterfly or slide uses a coil controlled by the ecu.....they get gummed up with oil vapour from the emmisions/breather lines coming off the tappit covers and crankcase.....yeah make sure you clean this well if not replace the whole unit ...
next would be to replace the temp sensor on the coolant manifold tube under the intake manifold ...it has an plug on it not a spade terminal ...this reports back to the ecu and can do funky things with idle..... my datascan tool shows what this is so its easy to diagnose a faulty one....i had one on my ej25 bus that read something like minus 10 ....and as a result gave me a 3k idle speed :shock: replaced this and all was good.....
but check simple things first like throttle cable....mine is starting to stick just off idle if i dont drive the buggy for a little while....must need to get it out more :lol:
shane2610
Re: Ej
Postby shane2610 » Tue Jun 03, 2014 4:00 pm
Thanks Paul that fixed it cheers shane.
Return to “Engine and Driveline”
Users browsing this forum: No registered users and 3 guests
