Radiator
shane2610
Radiator
Postby shane2610 » Tue Aug 26, 2014 7:36 pm
Hi everyone,I am going to put my radiator up the front. Has anybody got any photos of this done? Did you use copper or rubber pipe to go down the side of the buggy? Cheers Shane
mattie182
Re: Radiator
Postby mattie182 » Tue Aug 26, 2014 7:59 pm
When I did mine.....
I used allot pipe work, which was bent up a the exhaust shop to follow the contours of the body
Rubber pipes connected it all together
At the High points, I had bleed screws to help with filling
TezCat
Re: Radiator
Postby TezCat » Fri Aug 29, 2014 7:59 pm
Where are you located
AS026
shane2610
Re: Radiator
Postby shane2610 » Mon Sep 01, 2014 1:16 pm
Bribie island
Re: Radiator
Postby PUD » Tue Sep 02, 2014 6:42 am
G'day Shane, not sure if it's any use but here's a pic of the rad mounting on the ol' girl. It's a bit rough but seems to be holding up well, although will need to replace the fan with better shrouding to pull more air flow, as it struggles a bit when the going is slow.
Looks like yours is coming along nicely, more progress pics would be great! Pud
