Type 4 engine build .
occy8
Postby occy8 » Sat Oct 25, 2014 8:23 am
Hey guys , just finished converting a 2 L type four into an upright for a bit more power in the buggy. A good friend had a Kombi sitting out the back of his place and kindly gave me the engine . It was in bad nick on the outside but turns out it was a 2 L . So stripped it back to small block cleaned it up and ordered upright kit from mike at sharpbuild and new 96mm c&p for US ,reground valves and seats got hold of a set of 40 dells and 4 into one exhaust from samba . Put it all together and you can see the results , just workin it in now , drives heaps stronger and feels fast. Now need to fix up a cage .
Started here
occy8
Re: Type 4 engine build .
Postby occy8 » Sat Oct 25, 2014 8:26 am
Cleaned it up
occy8
Postby occy8 » Sat Oct 25, 2014 8:27 am
This happened
occy8
Postby occy8 » Sat Oct 25, 2014 8:31 am
Sold my old engine and put it in another mates buggy.
occy8
Postby occy8 » Sat Oct 25, 2014 8:34 am
End result was this
Postby Vduboy » Sat Oct 25, 2014 2:28 pm
Very cool, what did the sharpbuilt kit consist of? How much? Just need do something about the exhaust, its huge! What motor did you have in it previously?
Postby DDWR450F » Wed Nov 26, 2014 9:38 pm
Great work Occy, I wish I knew how to rebuild and pimp up my 2lt.
What's an upright kit worth mate?
