kombi box crownwheel reversal
If it makes power or helps it get to the wheels this is where it is at
Postby PUD » Thu May 14, 2015 12:52 pm
Had some wierd thoughts since a slow rocky run recently :? from memory in the early swingers it was possible to turn the crownwheel to reverse the axle rotation....am curious to find out if this is do-able in a 3 rib 1600 irs box (without the reverse cut etc) .....(forgive me, but it has been mentioned on here before that there's no such thing as a silly question :oops: )
Re: kombi box crownwheel reversal
Postby VWNuts » Thu May 14, 2015 9:28 pm
The answer is no.
My Kombi Ute used to have reduction boxes that were modified to have a cv flange. But the whole gearbox was flipped upside down to reverse it.
Postby PUD » Fri May 15, 2015 6:10 am
Would love to see a pic of the setup :) not sure how it would work bolting it up to a modified arm... Don't recon will do anything but just looking at the possibilities, as don't do much long haul road work & even with the 1600 box, still tends to be a bit tall in the gearing in the tight stuff. As you'd already know, reduction hubs would tick a few boxes, i.e. get an extra bit of lift, straighten out the driveshaft angle, & with the inertia of the axles turning the opposite way tends to make the ass end lift (providing more clearance) when you boot it....maybe a stock subi 5speed to couple up...axle lengths might be an issue... also heard mention there's potentially a difference in the very early model to later reduction hubs, potentially the spline size??
Postby Brad » Fri May 15, 2015 8:19 am
I Think Nuts has Gyro and it had one
Postby PUD » Fri May 15, 2015 9:41 am
Wow!! That's different! Very innovative, thanks for posting :D
Postby manxiberty » Fri May 15, 2015 9:52 am
yeah just need to roll the car over for oil changes :shock:
Postby bajabone » Fri May 15, 2015 9:59 am
manxiberty wrote:yeah just need to roll the car over for oil changes :shock:
I can arrange that for you!! Lol.
Postby VWNuts » Fri May 15, 2015 7:36 pm
The second pic that Brad posted is our Ute. Yep used to be known as Gyros
Postby PUD » Sun May 17, 2015 7:57 am
Cool, guessing they're still fitted? Nice to see they've lasted ok, not something that gets modified & only lasts a few hundred K's, any end loads on the bearings by the cv's/ shafts etc must be ok :) Extra unsprung weight of fitting em on a buggy might be something to think about, also poking a few extra hp at em, although the gears themselves look pretty chunky
Postby VWNuts » Sun May 17, 2015 9:41 am
The reduction boxes were removed from our ute before we got it as the wheelhop with the 3.8L V6 was too much
Postby PUD » Wed Jun 03, 2015 6:14 am
Return to “Engine and Driveline”
Users browsing this forum: No registered users and 3 guests
