Our Baja Bus ( Yes i'mm back at it again )
Re: Our Baja Bus ( Yes i'mm back at it again )
Postby Brad » Mon Dec 31, 2012 1:44 pm
If he sells it at least it will get finished :-)
Postby OzTowdster » Mon Dec 31, 2012 5:39 pm
Still at it folks , rear passengers side and back corner all stripped and etched , and have also finished off around the tops of the window openings every where , so only the front passengers door and sliding door jambs and the roof left to strip and etch and then on to the bolt on panels for the same .
Have also today , wire brushed , scrubbed and scuffed most of the interior sheetmetal and etched the cargo floor .
Postby Brad » Tue Jan 01, 2013 2:59 pm
I hope you aren't doing all that scrubbing withouty some help from the driver ..
Postby OzTowdster » Tue Jan 01, 2013 6:40 pm
I did suggest the idea , and got much the same response you would get from Jen , so no it's solo effort so far.
Got some more done today too , in those 2 door opening are now all stripped and etched , so on to the roof tomorrow hopefully and or clean up all the inside of nose and ducting and etch most of it .
Either way i'll be moving foward which is nice
Postby OzTowdster » Thu Jan 03, 2013 8:57 am
Been at the bus for a few more days now and have basicully got everything below the roof stripped and in Etch Primer which is huge job on any bus when your doing all the stripping with paint stripper and mainly a 40mm wide scraper .
The inside area's have been just servely wire brushed with and the angle grinder and then scrubbed with some hand paper and random orbital where possible with the emphasis on having a nice clean finish and no hidden brown spots under the primer
So heres a few shots
Postby Smiley » Thu Jan 03, 2013 3:12 pm
Someone has been getting keen for a change!!
Postby BlueV2 » Thu Jan 03, 2013 3:15 pm
Someone has been working hard.......good to see !!
Postby dbryar » Thu Jan 03, 2013 3:45 pm
I thought that yellow thing on the pedal/steering wheel was some sort of lock before realising it was just a bungee hook. O.o
Other than that, epic effort. Any reason you didn't sand blast off the old paint and whatnot?
Postby OzTowdster » Thu Jan 03, 2013 7:14 pm
dbryar wrote:I thought that yellow thing on the pedal/steering wheel was some sort of lock before realising it was just a bungee hook. O.o
The $2500 quote had a fair bit to do with it , not to mention it's a 3 month wait to get into the only person everybody trusts with kombi panels that don't come back looking like the pacific ocean
Postby OzTowdster » Thu Jan 03, 2013 7:17 pm
Well all the rest of the inside is cleaned up and primed now and have also started cleaning all the horrid flakey tar of the inside of the wheel arches
BAJAKOMBI
Postby BAJAKOMBI » Thu Jan 03, 2013 7:24 pm
Too true man! When i got the other halfs kombi back from a guy i have used for years, it was a mess. i have had to put 2x extra braces in the roof because it was so badly stretched.The roof looked like somebody had walked on it. It has taken me 2yrs of spare time to get it straight again. :x
Postby OzTowdster » Sat Jan 19, 2013 7:47 am
Not much to report of late , have been repairing one of my drivers door outer skin , and was repairing a pretty rotten sliding door because i couldn't find any others but that is now a right off .
The good news is though that svieki or h has found me a pristine sliding door in Sydney , Thanks bud
Have also been under the bus of an afternoon with the scrappers , and a grinder fitted with a wire wheel cleaning off 36 years of crud mainly buried under bloody body deadner where someone was to lazy ( NOT ME ) to clean everything prior to applying the rubbery layer .
Have got to get the Towdster rolling this weekend so it can go to Steel Art for some work over the next few weeks , so that will free up some space here and i'll get into the body filler etc hopefully this week after work
billy1770
Postby billy1770 » Mon Jan 21, 2013 10:49 pm
Hey Towdster, i'm freshly returning to this v.w. love thing. and I must say i'm impressed with your work. You must bring it up to 1770 for show and tell when she's finished.
I'm not completely useless...
I can be used as a bad example !!!
sveiki
Postby sveiki » Tue Jan 22, 2013 12:56 pm
pics pics pics :D
happy to be here
Postby Smiley » Tue Jan 22, 2013 8:48 pm
Surely it's got some colour on it by now? :lol: :lol: :lol:
