Super Sports Rebuild
sparx
Re: Super Sports Rebuild
Postby sparx » Mon Aug 24, 2015 9:14 am
BTW does this look right?
sparx
Postby sparx » Mon Aug 31, 2015 5:44 pm
Hi Guys,
Got the pan in at work for painting, just need to cut the hand hole for the clutch cable ( great idea BTW)
And the cross piece for the pedals.
the pedals I have are pretty crusty this bug seems to have lived under the sea for a while.
Does anyone have a photo of one of these as I will need to make a the new bush.
Also does anyone have a spare steering arm? Mine is stripped out.
1970 Ball joint FE RHD.
Postby BlueV2 » Tue Sep 01, 2015 1:09 pm
Is that the accelerator arm ?
sparx
Postby sparx » Tue Sep 01, 2015 4:03 pm
That's the one. Pretty eaten out.
Postby BlueV2 » Tue Sep 01, 2015 5:50 pm
Pretty sure I can find you an accelerator arm and probably the Pitman arm as well. I will be up in Cains at the end of the month if that helps ?
sparx
Postby sparx » Tue Sep 01, 2015 8:06 pm
Wow that would be huge.
I'll send you my phone number.
Do you know any Bettle/Buggy nuts in Cairns?
sparx
Postby sparx » Wed Sep 02, 2015 3:35 pm
made it to the paint shop.
I still have the pedal support cross peice and the access hole to fit but I'll get that done tomorrow tonight and hopfully painted by saturday.
sparx
Postby sparx » Wed Sep 02, 2015 8:31 pm
Anyone know what model kombi box this might be? :D
Postby BlueV2 » Wed Sep 02, 2015 9:09 pm
I think it is a Kombi 1600.
Postby BlueV2 » Thu Sep 03, 2015 1:03 pm
Will these do for what you need ? The accelerator arm is not the one I was looking for, so if I can find the better one then I will bring it to Cains.
sparx
Postby sparx » Thu Sep 03, 2015 2:13 pm
yep looks great.
thanks heaps.
sparx
Postby sparx » Tue Sep 08, 2015 5:34 pm
Finally the primer is on!
Postby josh702 » Tue Sep 08, 2015 7:17 pm
Its looking pretty good mate, are you going to use a bed liner type paint or two pac finish.
sparx
Postby sparx » Tue Sep 08, 2015 8:59 pm
That's the primer, next is sealing the seams and then the two pack top coat.
I was thinking of bed liner or similar underneath.
sparx
Postby sparx » Sat Sep 19, 2015 8:42 pm
Finally.
