Fastest Buggy Around .....
Postby Brad » Mon Feb 15, 2016 4:54 pm
Well when it comes to building fast buggies you may think I am talking about building a buggy that will go quickly ... now although I don't mind a bit of speed in this case I am talking about building a buggy quickly.
With Bruce's Birthday not to far away we have just started building the last of our Bruce's Birthday Specials and fittingly it is a Meyers Manx Kick-Out Traditional in Dragon Red, kind of cool really being the same colour as Bruce's own Kick-Out Traditional.
This Kick Out is number 71 and is the 1st Buggy of 2016 which is kind of cool being Bruce's 90th year.
Like all the Buggy Builds at Turn Key Manx we are well aware that building the actually buggy is not really that hard once you have your parts list down pat and have a few under your belt. In this case it is not the 1st Kick-Out we have built and am sure it will not be the last.
With this build we have teamed up with The Manx Shop ( www.themanxshop.com) to provide all the parts we need so anything you see in the build can be purchased from The Manx Shop and I will provide links as we go. There is also a new Category on The Manx Shop ( Buggy Kits -> Buggy Builds ) which list the Buggies and shows all the parts used. ( http://www.themanxshop.com/index.php/bu ... uilds.html) I will do my best to keep this up to date but it may run a few days behind the actual build as there are only so many hours in the day and priority goes to building.
So what are we building ?
We are Building what I refer to as a Back in the Day Manx. By this I mean that we are not trying to set the world on fire with new technology or waste a heap of money of expensive parts. We are using the last 20 plus years of experience to put together a slid package which should give the owner many years and miles of smiles.
Body - Meyers Manx Kick-Out Traditional - Dragon Red
Chassis - Turn Key Manx Ball Joint / IRS Roller
Brakes - 4 wheel disc brakes 5 / 4.75 ( Chevy ) PCD with Hand Brake
Transmission - Fully Rebuilt Type 1 IRS
Wheel and Tires - Turn Key Manx Buggy Wheel Pack - 15 x 6 and 15 x 8 with 31" and 205 Tires.
Engine - 2nd Hand 1600 TP with a full service and dress kit
Seats - PRP Buggy Seats - Custom Trim
Electrics - VW Gauge - New Turn Key Manx Buggy Loom
That is about it, built from the ground up using parts we are happy with and like all our Builds backed by a full warranty so the customer gets what they expect and we get to build to the standard we love.
Anyway sit back and enjoy, if you have any questions please feel free to contact us ( sales AT TurnKeyManx.com )
Re: Fastest Buggy Around .....
Postby Brad » Mon Feb 15, 2016 5:04 pm
The Build begins like most with finding a suitable Donor Bug. As we prefer to use Twin Port 1600 Engines and IRS Transmissions we started with a 71 Super Bug. Although this means we can't easily use the floor pan that was ok as we have a good stock of Ball Joint / IRS Pans with clear title.
The Car we go was a solid runner, we were able to test drive it and make sure the engine was healthy before purchase and got a good transmission as well. Since we get all our transmissions rebuilt to ensure there are no issues we pulled it and sent it off to The Wright Gearbox ( http://www.wrightgearbox.com/) for a full rebuild.
While that was happening we headed over to Meyers Manx HQ ( http://meyersmanx.com/) where Winnie was ready for us to pickup the Kick-Out Kit we ordered back in early January.
Like all Meyers Manx Kits the Kick-Out is a very complete kit which makes building it a pleasure. When you goto get your kit Winnie runs you through every item you get and makes sure you are happy and understand what is what. She then ticks it off the Sheet to make sure nothing is missed. Winnie does this on every kit, even after more than a few she still goes through each and every item with me which is a nice change from some shops who just want you out the door.
The Kit comes with all the mounting hardware and fitting instructions. These are each packaged and labeled in accordance with the instructions making it easy to find what you need.
Even after all these years this little tag is still what most Buggy Builders want, the name that started it all and is still going strong with a quality others have often failed to achieve.
Postby Brad » Mon Feb 15, 2016 5:06 pm
The owner of this Build asked for the dash to be signed, luckily for him Bruce didn't mind a bit and happily obliged.
So with the sign off done ..
Winnie was happy for me to load it up and head back to the Shop to start the Build ..
Postby BBTJ » Tue Feb 16, 2016 4:25 pm
Cooooool.
Are you done yet ???? :wink:
sjmclean
Postby sjmclean » Tue Feb 16, 2016 4:40 pm
Nice will be watching this Brad.
Stu
Postby Brad » Tue Feb 16, 2016 5:26 pm
When it comes to buggy building it is very important that you have solid bones. Every Turn Key Manx Build is done on one of our fully rebuilt VW based Floor Pan or Custom Tube Chassis. In this case we will be using a Type 1 Based Floor pan which is IRS in the back and Ball Joint up front. The pan is removed from the donor and then we strip it bare before cutting it and using our custom alignment jig to ensure correct fit. Once we are happy we weld it in place and send it out for Sand Blast.
We do it in this order so all real fab work is done on a clean pan and we can get the best quality possible.
Seems that everywhere I turn I have Buggy Pans being built, good thing I can fit lots in my truck each run to the Sand Blaster.
The Sand Blasting is done by a local guy who use Wet Media so we can get all the seam sealer and tar stuff off. It makes a heck of a mess good thing he has a booth :)
Once we get it back we have a nice looking pan and can begin to give it some fab love
Postby Brad » Tue Feb 16, 2016 5:38 pm
When it comes time to do the floor pan halves we use only Heavy Duty units from Wolfsburg West. It is important that all corners are cleaned of any old pan traces. We do this with a die grinder so we know it is smooth .
The pan halves are put in by punching holes along the edges so we can plug weld and then linish down. Factory are spot welded but we don't have a spot welder so this works. We use a pneumatic punch so there is no distortion to the seating face like you get when you drill .
As far as the tunnel goes once we have it welded out we add one of out custom tunnel gussets. These are designed to avoid any issues with cracking and relive any stress we may get around the join.
We put these in with a specific weld sequence to ensure each one fits just right.
With the join taken care of we put a tunnel access panel in place to allow easy access to the clutch tube and pedals. We seam weld this after clamping the double panels in the tunnel to the lip so we can seam it all together. This is very important and ensures years of faithful service. So confident are we in this method if any pan we have built ever cracks we will repair it free of charge. This is why we cut our logo in so there is no doubt of which pans are ours.
While we are doing this we do a number of small touches that makes a Turn Key Manx Pan all the better and avoid any known issues. For example the clutch tubes are often an issue and break free. To avoid this we clean them off and wedl them out.
When we do this we put a machined plug up the end to ensure no slag heads in and there are no issues with the tube when finished. If you don't do this you can blow through and have issues with clutch cables.... no fun especially when you have the body on and want to go driving...
Then we put in the floor halves, do some more cool stuff and it is onto the rotators and off to seal, paint and rust proof.
Postby Brad » Wed Feb 17, 2016 6:11 pm
Solid base means a solid buggy. The Turn Key Manx Pan is built, sealed and ready for action.
Being this was part of a Turn Key Manx / Meyers Manx Special it got one of the Meyers Manx Tunnel Covers and Serial Numbers
Like most of our Pans it was sand blasted, sealed and then coated in a Bed Liner called Armadillo which is a great thing and very tough.
Just like the Buggy Gods would have liked the Germans to make.
No pan cracks here
Postby Brad » Thu Feb 18, 2016 2:51 pm
With the Buggy Pan taken care of it was time to turn our attention to the rest of the Buggy.
Now a lot of people may think the way we build a buggy a bit crazy as we spend more time preparing than actually building, well at least it seems it some times :roll:
So we have been ordering the parts we need as as they arrive they are unpacked, inventoried and stacked on one of our Buggy Build Shelves. These shalves were designed to hold one Buggies worth of Parts. Once the shelve fill up we know it is getting close to go time.
Over the last 20 plus years we have found that we achieve much better results if we have all the parts before we start the build. By doing this we are able to stay focused and avoid embarrassing over sights.
Now since most buggy people are visual it is always hard to be certain you have everything until you lay it all out and walk around doing a Brain Build. A Brain Build is a game we play where we talk through the build and try and identify parts that are missing to finish the job. Sounds silly when you say it out loud but it allows us to make sure we are right to go.
So we start with the Buggy Kit, in this case a Meyers Manx Traditional.
We sit in on the shop floor and begin our Brain Build using what is on the shelf and our imagination.
Wheel and Tires
Build Time is sort of cool :)
And then we just keep going
Till we have what starts to look like a Big Boys Model Kit !!!
Postby Vduboy » Thu Feb 18, 2016 7:33 pm
That is a awesome shot! Love this build thread, entertaining as usual Mr Brad!
Postby Smiley » Fri Feb 19, 2016 8:42 am
What is the tube for in the first shot with the body? Wiring loom conduit?
Postby Brad » Fri Feb 19, 2016 5:54 pm
Smiley wrote:What is the tube for in the first shot with the body? Wiring loom conduit?
Correct
Postby Brad » Thu Mar 03, 2016 6:41 pm
Wow the days are flying by and it seems updates have been as fast as I would have liked. It is amazing how much effort it takes to keep pictures and info flowing when you are trying to stay on track with the build.
Anyway ...
So we had the buggy laid out and where inspecting it all to make sure we had the parts we needed to make it all come together on time and quality. One of the parts we use which isn't off the shelf is our brake line kit. These are custom made for us and are fully DOT Compliant. The main thing that drove the need was the lack of suitable brake hoses to suit the rear disc brake kits we use. The kits consist of 4 DOT Compliant Braided lines and fittings to go into the VW lines as well as Banjo's into the rear calipers.
By using the kit you get to remove the need for several hard lines and reduce the chances of leaks.
Up the back it lets you get away from the horrible hard line to the caliper or the small flex lines that come with the kits. By using the Caliper upside down with Banjo Bolt you get to keep it all nice an tight and get a much better hand brake cable setup. The down side is bleeding is a PITA but once done it is not really an issue.
Postby Brad » Wed Mar 09, 2016 4:36 pm
While the pan was getting finished it was time to start on the loom. Although there are a number of looms people seem to use in Buggies I prefer to make my own as all the ones I have seen are a compromise and leave gaps in areas. By doing it in house we can control the quality and make sure we are happy with it going into one of our builds.
Now there is no rocket science to making a buggy loom, an aircooled VW is hardly complicated and it really just takes time and a few terminals and some wires. Over the last 20 plus years I have learnt a few tricks but the main one is knowing where to get the components I like to use.
Like most looms we start with wire off the roll. We have two options but for this build it will just be Automotive grade Vinyl and Multi strand copper .
It them gets laid out on the board like a game of battleships. The board has a threaded holes every 100mm and I use different pins for different purposes. In the case on a Kick-Out I have a picture of where the pins go so I can lay it out without having to re-measure it off the buggy
For example at 1-19 is the rear intersection coming out of the harness tube. while 9-19 is the starter motor and so on.
Once everything is laid out I begin to loom, heat shrink and terminate it.
Once done it is pulled off the board and ready to go into the Buggy
Like all out builds we use the same weather proof fuse block and sequence
Now we just need the Buggy finished to put it in
Postby Vduboy » Wed Mar 09, 2016 8:37 pm
Love the peg board idea dude.. very cool! And I wish i'd done the braided lines straight out of the master cylinder for the front brakes too.. looks a lot neater.
