Oz Towdsters , Towd Build
After years of working with others Paul has stepped out of the shadows and is showing what he has to offer in the Buggy Building and general Automotive Fabrication Arena. Located in South East QLD, Paul ships Australia and Worldwide with no job to big or small.
Re: Oz Towdsters , Towd Build
Postby OzTowdster » Wed Aug 20, 2014 4:55 pm
The front guards on my Towdster starting to take shape to cover the wider stance and longer up travel
Postby Brad » Thu Aug 21, 2014 6:35 am
Holly Crap that's fat ..
Postby Brad » Thu Aug 21, 2014 6:39 am
Postby Vduboy » Thu Aug 21, 2014 12:07 pm
Hahaha I like the last pic! How much wider is that than a "standard" one? It's going to be huge, road rego'd?
Postby BlueV2 » Thu Aug 21, 2014 12:41 pm
Yeah I was going to say, "put some ailerons on those guards and you will get good front end lift" :!: :D
Postby Smiley » Thu Aug 21, 2014 1:03 pm
Are they braced with steel or alloy at all? Or just going to be all glass?
Postby OzTowdster » Thu Aug 21, 2014 3:59 pm
All glass at this stage , as my fiberglasser has a few idea's with using certain matt's to give it the strength where they need it but still let them flex enough to not just crack
Postby PUD » Sun Aug 24, 2014 7:30 am
That looks awesome, nice lines! Looking forward to pics with wheels fitted to give it perspective & scale :D
Postby OzTowdster » Sun Sep 07, 2014 8:26 am
Bit more done lately and some other stuff starting to get finished off .
The rear infill panel and modified Trimil Bobcat exhaust .
The front skid plate which will have a 250mm x 220mm hole cut into and ducted up to my engine oil cooler to give it good clean cool air
Not that you can see much of it but the alloy fuel tank in place
The modified Jamar brake and clutch pedals and Pauls custom made throttle pedal which will keep the floor clear
The centre consul with jamar X shifter
Postby Vduboy » Sun Sep 07, 2014 10:41 am
Looking very sweet mate! Good to see more getting done on this! Want to see some more vids of it in action!
Postby wallace » Sun Sep 07, 2014 11:51 am
What are the advantageous of the Jamar shifter?
Burn your hands in an open top car?
Postby Brad » Sun Sep 07, 2014 3:21 pm
Vduboy wrote:Looking very sweet mate! Good to see more getting done on this! Want to see some more vids of it in action!
Sure :D
Oh you mean something that ain't 10 years or older ... sorry nothing to see here :roll:
Postby OzTowdster » Sun Sep 07, 2014 5:43 pm
wallace wrote:What are the advantageous of the Jamal shifter?
Never mind the alloy knob , as yes the car will have a roof of sorts .
The advantage's of the jamar X shifter are great in that it is a sealed unit , and unlike most items of this type , it has a reverse lock out the same as a stock VW ( ie you push down on the stick to enter the reverse pattern ) and it is easy to mount being all one unit .
See below for an unfitted picture of the unit
Postby manxiberty » Mon Sep 08, 2014 7:18 am
it also gets rid of the primitive shift rod with the ball and socket arrangement which in a towd would soon fill up with crud with the lack of bottom on the tunnel area. the internals of the shifter are much more refined giving a nice shift. it enables you to run some uni joints for the shifter to get rid of all those areas where a little wear makes your shift feel like a bowl of porridge.....
and plus we can turn a $20 setup into a $500 setup so why would we :lol: :lol: :roll: :roll:
and plus leather/plastic shift knobs are cheap..... 8)
Postby wallace » Mon Sep 08, 2014 4:59 pm
manxiberty wrote:it also gets rid of the primitive shift rod with the ball and socket arrangement which in a towd would soon fill up with crud with the lack of bottom on the tunnel area. the internals of the shifter are much more refined giving a nice shift. it enables you to run some uni joints for the shifter to get rid of all those areas where a little wear makes your shift feel like a bowl of porridge.....
Fair enough. All valid points :D
Return to “SteelArt Creations - Buggy Build SE QLD”
