Short torsion bars & matching spring plates
ancientbugger
Postby ancientbugger » Sun Apr 07, 2013 12:48 pm
My son has bought some OTT mudtyres which were supposed to be 31" s but in fact just touch the elongated torsion bar housing so as it says we're after shorter torsion bars and the matching spring plates, we have the 'flat' covers.
Barry
Re: Short torsion bars & matching spring plates
Postby Brad » Sun Apr 07, 2013 1:04 pm
ancientbugger wrote:My son has bought some OTT mudtyres which were supposed to be 31" s but in fact just touch the elongated torsion bar housing so as it says we're after shorter torsion bars and the matching spring plates, we have the 'flat' covers.
Barry
Hi Barry,
What you need is swing axle spring plates which are cut down to match IRS holes, if you have an IRS rear end.
If you contact Paul at SteelArt Creations in Brendale he should have the fixture for making them and can punch a set out for you. If you have a swing axle rear end then you just need some earlies and you can get them from Pete at Custom Vee Dub in Stafford as he has a few of them upstairs.
ancientbugger
Postby ancientbugger » Thu Apr 18, 2013 9:06 am
Well we have the spring plates sorted but are finding that the short (550mm) torsion bars are a bit light on the ground!! Surely someone has a couple sitting around. :?
Postby Tratty » Thu Apr 18, 2013 10:04 pm
I'll have a look for you no promises though :)
ancientbugger
Postby ancientbugger » Fri Apr 19, 2013 8:50 am
Good on ya Tratty! Springplates arrived this morning as well :D
Postby Smiley » Fri Apr 19, 2013 3:55 pm
Is it swingaxle bars you're chasing? the ones that don't protrude at all through the springplate?
If so I can bring you down a pair. I have a few sets lying around. I'll be down in Brisbane next weekend from the 25th-28th. And then the following weekend aswell from 3rd-5th.
Could drop them off on the way down or the way back. Let me know if you can't find them anywhere else.
Postby bajabone » Fri Apr 19, 2013 6:51 pm
Yes the swinger bars are the one's to use.
ancientbugger
Postby ancientbugger » Fri Apr 19, 2013 7:24 pm
Hey Smiley they're the ones, if you could bring them down that would be great!
Postby Smiley » Fri Apr 19, 2013 9:06 pm
ancientbugger wrote:Hey Smiley they're the ones, if you could bring them down that would be great!
That's no worries at all. How many are you chasing?
ancientbugger
Postby ancientbugger » Sat Apr 20, 2013 8:48 am
Just a pair as he only has one baja :D
Postby Smiley » Sat Apr 20, 2013 10:07 am
ancientbugger wrote:Just a pair as he only has one baja :D
Ok. No worries. I'll get in touch via PM this coming week. :D
Postby Smiley » Wed Apr 24, 2013 11:03 pm
Barry.
You have PM :D
