for hire the tilter pictured below
Want something for your Buggy ? Here is the place to post
ernie norley
Postby ernie norley » Sat May 11, 2013 4:09 pm
G'dy all. I need to roll ECLECTIC on it's side to weld in chassis boxing & setup midmount engine transmission cradle. willing to hire it for approx 6 weeks may be less. anywhere between Gympie & the goldcoast if you can help out please PM me with details. I have obtained the tilter pictured below. It will be available for hire.
thanks
Ernie
ernie norley
Re: wanted to hire bay rotisserie
Postby ernie norley » Fri May 17, 2013 8:34 pm
G'day all I obtained a tilta tech body tilting set up today it bolts to front wheel studs on 1 side & both rear sets of studs safe up to 1750kgstilt is controlled by power drill it can be disassembled & carried in boot. Once I have used it to box the kombi chassis it will be for hire between sunshine coast & gold coast pick up return.
ernie
Postby BlueV2 » Mon May 20, 2013 1:29 pm
That sounds great for people who need to turn their buggies over !!
ernie norley
Postby ernie norley » Mon May 20, 2013 3:38 pm
G'day blue2v. this is a pic of the unit. you can use a ratchet or power drill to lift with. It disassembles & fit's in your boot. easy to transport.
ernie
Return to “Wanted”
