WTD - Clamp for Coil Over Spring on Shockabsorber
moss
Postby moss » Mon Nov 03, 2014 10:59 pm
Hi Guys,
I broke my aluminium clamp on the shockabsorber that holds the coilover spring on to the shockie. Would anyone have one lying around?
Mark
Broken Clamp
IMG_6008 (200x150).jpg (42.37 KiB) Viewed 1536 times
Clamp on Shockie
IMG_6011 (200x150).jpg (41.01 KiB) Viewed 1536 times
Coil Over Shock
IMG_6010 (200x150).jpg (39.41 KiB) Viewed 1536 times
Re: WTD - Clamp for Coil Over Spring on Shockabsorber
Postby Brad » Tue Nov 04, 2014 6:29 am
Try Paul at SteelArt he should be able to help you out. I think he ended up with the Jigs for the coil over clamps and if he didn't Dyno will have them and Paul will be able to get a set off him.
