If you are a Business then you can post buggy related parts in here
Postby ttriebler » Thu Apr 15, 2010 3:15 am
We supply reverse cut gears for Subaru 5 speed gearboxes so they can be used with rear engined cars such as Manx buggies. Boxes can be used in 4wd mode or converted to run 2wd.
Will fit into a type 1 beetle pan without cutting the torsion bar.
Can be used with a Subaru engine or with a VW/Porsche engine if used with an adaptor plate.
Check out for all the details.
Return to “Business Adds”
