Oz Towdsters , Towd Build
After years of working with others Paul has stepped out of the shadows and is showing what he has to offer in the Buggy Building and general Automotive Fabrication Arena. Located in South East QLD, Paul ships Australia and Worldwide with no job to big or small.
dylan
Re: Oz Towdsters , Towd Build
Postby dylan » Thu Aug 15, 2013 9:52 pm
By the time you finish it will it have an aircooled motor or a FLUX- CAPASATOR :lol:
Postby manxiberty » Sat Nov 23, 2013 5:24 pm
Well we must of been getting withdrawal symptoms from not working on a towd so the build continues….
The hook and pin stops on the front beam have now been pretty much finished which will prevent the leverage of the longer arms folding back under certain reversing circumstances i.e. up a hill or reversing into an obstacle….also a resting point whilst airborne…..
Once these were finalised the spring pack had some loving with a bit of tuning as the front end of a towd is lighter then most other offroaders
Wheels were put back on and we wheeled it out to see what the overall stance looked like
Postby bajabone » Sat Nov 23, 2013 7:16 pm
Overall stance is good! Now you can drive over a fisherman's bucket and tackle box on the beach without disturbing the peace.
Postby Brad » Mon Nov 25, 2013 2:46 am
bajabone wrote:Overall stance is good! Now you can drive over a fisherman's bucket and tackle box on the beach without disturbing the peace.
Dude now you are being silly, they will be to drunk to push it around on the beach and Andrew has never got any of his projects driving again after pulling them down.
Lovebuggy
Postby Lovebuggy » Tue Nov 26, 2013 8:34 pm
That is why he has Paul involved to get it sorted.
Are you a financial member of the club??
Go to "http://www.manxclub.org/phpbb3/viewtopic.php?f=50&t=1667" and sign up today.
OzTowdster
Postby OzTowdster » Sun Dec 22, 2013 1:00 pm
nally recieved our container from the states so Christmas has come early here
My HID headlight kit which will be fitted into a pair of genuine KC Stainless Steel Dayligters
Speed hut Gauges , including a combined Tacho / GPS Speedo , Oil pressure , Oil Temp , Cyl Head Temp , Volts , and Fuel , with all senders
A genuine Bosch Alternator and tig welded wide fan
A Jamar Pro X shifter with reverse lockout
Also unpictured at present is a set of Jamar hydralic fiddlers/ turning brakes , various size bump stops , some new cylinder tinware that i will insert the cylinder head vane out of a german set into , a 36 hp doghouse fan shroud and some LED tail lights
Working at getting my Towdster and the Baja Bus back on the road !!!
Matt
Postby Matt » Sun Dec 22, 2013 7:12 pm
Looks like a nice collection of parts.
Towd is looking good.
OzTowdster
Postby OzTowdster » Sun Feb 02, 2014 6:57 am
Bit more work , have set up the upper bump stops and limit straps in the rear
And cut out my centre consul to fit in the hydralic turning brakes , sorry forgot to take anyphoto's of the finished mounted item
Postby manxiberty » Sun Feb 02, 2014 6:52 pm
I can help there,
heres the bracket/mount for the turning brakes/fiddlers....
notice the curved notches....this sits on the seat belt mounting bar behind the seat area.....
should work well with just enough clearance for the shift shaft to go under it....
also did a cover plate with two slots for covering the hole but i didn't get a photo of that......
Postby Brad » Thu Mar 27, 2014 5:06 pm
This done yet ??
I'll race you ....
Postby Brad » Sat Mar 29, 2014 3:27 pm
So are we racing of what ?????
OzTowdster
Postby OzTowdster » Sun Jun 01, 2014 8:45 am
Long time no posts , no excuses but i have been working on it !!!!!!!
Have cut and folded most of my new fuel tank out , which uses the triangular void that it fit's into better than the original round tank and the new tank should hold around 55 to 60 litres , sorry no photos' of this yet
Yesterday we also finally got stuck into the rear mudguards / fenders which we have moved out approx 50 mm and back 55 mm to cover my large rear stance .
The plan with the guards / fenders is to cut ,modify , and clean up the existing guards , use these as plugs for a mould ( the existing guards are in very poor shape have been modified a few times already and weigh way to much ) and produce a couple of sets , ie one set to go on the car and a spare set .
Any way here are a few pics of the progress so far
Postby Brad » Sun Jun 01, 2014 3:04 pm
Damn it is looking very American in that shop with all those home boy sneakers getting around, no wonder nuffin is happening... :shock:
OzTowdster
Postby OzTowdster » Sat Jun 14, 2014 9:11 pm
It's all good sunshine , your new booty's are all ready to go here , and i'mm packing my work boots too .
keep posted tomorrow night for more photo's of the enlarged Towdster guards
Postby Brad » Sun Jun 15, 2014 5:53 am
Ok cool, you need boots to get in and a big gut to fit in so sounds like you are go to go on both fronts, I know I am :(
Return to “SteelArt Creations - Buggy Build SE QLD”
Users browsing this forum: No registered users and 3 guests
