Brad’s – Manxter 2+2 Offroad Build, A-Arm, Subaru and Toys
If you are building a buggy or Baja then please post in here and share your experinces with us
Re: Brad’s – Manxter 2+2 Offroad Build, A-Arm, Subaru and To
Postby Brad » Thu Jun 12, 2014 1:42 pm
manxiberty wrote:with that head unit do you fold your cd's in half and feed them in ? :lol:
WTF is a CD ? Is that one of those old fashioned things that come in sleeves ?
wallace
Postby wallace » Thu Jun 12, 2014 5:51 pm
What type of stereo is that? Does it plug into your iPhone or Bluetooth?
The buggys looking good btw :D
Postby Brad » Fri Jun 13, 2014 7:04 am
wallace wrote:What type of stereo is that? Does it plug into your iPhone or Bluetooth?
It is a Jensen AM/FM/USB Compact Waterproof - http://www.jensenmarinedirect.com/jense ... tereo.html
Thanks for the feedback
Postby Brad » Sun Jun 15, 2014 5:48 pm
Well the UPS man came yesterday and dropped me off some much needed terminals to finish off my engine loom.
He also had some more Raychem DR25 3/4" heat shrink to do the looming and main runs. The main run isn't done with double and you don't want glue backed heat shrink as it reduces the flexability and is a PITA to get the long loom into.
So engine manifold loom was done.
And finally I could close it up and put the last connector on
Then just when I thought the day couldn't get any better I found another box at the door with some other needed parts ...
Postby manxiberty » Sun Jun 15, 2014 6:08 pm
air cond bits, yeah well you do see some high temps where you are but also some low temps once the sun goes down....but thats when your working on buggies so no need for any provisions for this :lol:
ttriebler
Postby ttriebler » Sun Jun 15, 2014 7:57 pm
You're one to talk - finished my Manx yet?
p.s. you don't need to over-engineer everything on it like above so that it never gets finished.
A Subaru wiring harness like the ones that work on a million cars per year will do just fine thanks.
Reversed gears for Subaru Transmissions
Fit a 5 apeed to your rear engined car
www.subarugears.com
WaterRat
Postby WaterRat » Tue Aug 12, 2014 5:19 pm
Hey Brad, so where did u end up mounting the ECU and associated fuses etc?
I've been playing around with the idea of putting the ECU in a weatherproof box, but haven't come up with a workable solution yet - can't seem to find a suitable "out of the way" location to put it :oops: Did u mount the ECU to the lid of the box, or have some sort of bracket in the base.
Also, love the idea of using weather pack connectors - that'll stop and moisture ingress :lol:
Ok, so if u haven't already worked it out, I'm fishing for ideas/inspiration :roll:
I may not have gone where I intended to go ... but I've ended up where I needed to be. :mrgreen: Douglas Adams.
Postby Brad » Thu Aug 14, 2014 4:46 pm
WaterRat wrote:Hey Brad, so where did u end up mounting the ECU and associated fuses etc?
Mine is no good to you as it is all custom and the Motec ECU's are water proof :)
Here is Bucks ..
WaterRat
Postby WaterRat » Fri Aug 15, 2014 7:35 am
Ok, thanks Brad. That's helpful, although I might considering mounting everything slightly higher - I have a "flooding" issue anywhere around water :oops:
Re: Brad’s – Manxter 2+2 Offroad Build, A-Arm, Subaru and Toys
Postby VWNuts » Thu Jan 07, 2016 3:29 pm
Did this Manxter end up getting finished?
Return to “Buggy & Baja Building”
