Finchy's Manx
Re: Finchy's Manx
Postby dbryar » Mon Apr 09, 2012 1:36 am
Wow that is seriously F...cked
BAJAKOMBI
Re: Finchy's Manx
Postby BAJAKOMBI » Mon Apr 09, 2012 4:27 pm
finchy wrote:well here it is
I wonder why you had no noise in first?
Re: Finchy's Manx
Postby finchy » Mon Apr 09, 2012 7:01 pm
I asked myself this aswell, the only explanation I could come up with is maybe lower revolutions & less load. When the noise first started I drove it with as little load as I could. 1st gear became noisy at Burpengary.
Re: Finchy's Manx
Postby finchy » Mon Apr 09, 2012 7:10 pm
I cant seem to find data on my box, my prefix only has 1 letter: H 4460 137. Any input anyone. There is no room in front or behind the H so its not like its corroded.
Re: Finchy's Manx
Postby VWNuts » Mon Apr 09, 2012 7:15 pm
What info are you trying to find out?
Re: Finchy's Manx
Postby finchy » Mon Apr 09, 2012 7:23 pm
Well the ring & pinion ratio to seems to be out of irs ? not sure but when I went to investigate I couldnt find info on the box because of only having the H. The Ratio is 4.125, Most common I think is 4.38. Graham will irs pinion fit swing axle.
Re: Finchy's Manx
Postby VWNuts » Mon Apr 09, 2012 7:43 pm
Is 4th gear on the end of your Pinion shaft splined, or has a single keyway?
Does your crownwheel has 6 or 8 bolts?
The problem you will have is needing all the special tools to set up the pinion depth and the jig for setting up the selector forks
Re: Finchy's Manx
Postby finchy » Mon Apr 09, 2012 8:23 pm
8 bolt crown, I understand about the pinion, but I will need to think about the selectors. Anyway not sure about 4th, can you tell me from these pics.
2011-04-02 006 013.JPG (52.19 KiB) Viewed 5151 times
2011-04-02 006 010.JPG (54.51 KiB) Viewed 5151 times
2011-04-02 006 006.JPG (54.83 KiB) Viewed 5151 times
2011-04-02 006 004.JPG (47.11 KiB) Viewed 5151 times
Re: Finchy's Manx
Postby manxiberty » Mon Apr 09, 2012 8:38 pm
i know its the easy way out....but i remember seeing a freshly rebuilt box down at custom vee dub.... pete was looking at finding an owner for.....not sure what it is exactly bar it was an irs beetle box of some sort (not much interest for me in anything other then a 1600 kombi box to a 2L kombi box) but it looks like yours....
give him a ring if your interested.....
pete @ custom vee dub
28 hayward st stafford
3356 4356
tell him paul sent you.....he may hang up on you though hehehe :lol:
Re: Finchy's Manx
Postby manxiberty » Mon Apr 09, 2012 8:39 pm
oh yeah it was painted red too......thats why i remembered it.......red is the fastest colour!!! if you didnt know haha
Re: Finchy's Manx
Postby VWNuts » Mon Apr 09, 2012 8:43 pm
8 Bolt crownwheel is the later one, so the IRS crownwheel will bolt to your swingaxle diff housing.
Can't tell from those pics, the smallest gear (4th) that you took off the Pinion shaft, does it have a keyway inside? or is it splined?
Re: Finchy's Manx
Postby finchy » Mon Apr 09, 2012 8:54 pm
VWNuts wrote:8 Bolt crownwheel is the later one, so the IRS crownwheel will bolt to your swingaxle diff housing.
2011-04-02 006 015.JPG (52.41 KiB) Viewed 5145 times
Re: Finchy's Manx
Postby finchy » Mon Apr 09, 2012 9:07 pm
manxiberty wrote:oh yeah it was painted red too......thats why i remembered it.......red is the fastest colour!!! if you didnt know haha
I thought Blue was or hangon is it Green, I did notice your rpms at red rock picking up quicker than at stockton.
Re: Finchy's Manx
Postby VWNuts » Mon Apr 09, 2012 9:22 pm
That's a splined 4th gear which is the later version, so yeah you won't have any probs getting an IRS crownwheel & Pinion to fit into your swinger box
Re: Finchy's Manx
Postby finchy » Mon Apr 09, 2012 9:43 pm
VWNuts wrote:That's a splined 4th gear which is the later version, so yeah you won't have any probs getting an IRS crownwheel & Pinion to fit into your swinger box
Thanks Graham, My side plates have about 4 or 5 gaskets on each side that was put on from last build any idea why, not on housing but on tube plate. Maybe to allow for warpage like (bolt holes) not a flat surface any more. Rekon, or is there another reason.
