Buggy Blend - The ultimate floor pan sealer !!!
See what Products we are developing, make suggestions on new products
Moderator: Brad
Postby Brad » Sun Aug 14, 2011 6:30 pm
After many years of trying to find a product that would do what I needed, which was protect my floor pan and tunnel from years of abuse and beach use with little cleaning Meyers Manx Australia has come up with what it has found to be a very effective solution.
Buggy Blend is a product which is mixed specifically for Meyers Manx Australia and provides not only a great floor pan sealer but also a rust-penetrating and moisture repelling coat which will bond to most surfaces. Surface prep is simple, give it clean, remove loose scales and apply. Let it dry for a few hours and then apply again if you want.
This is not a POR15 style product, it is aimed at buggies which are built and need a freshen up without a heap of surface prep etc. Easy to apply and great results to date.
Once testing has been completed it will be available through the Meyers Manx Australia website with a RRP of $49 for 2L which is more than enough to do a full floor pan and still have some spare.
As we are still in testing we are looking for a couple of abusive buggy owners to test it out and provide quality feedback. So if you think you are up to the task then post in here and we will contact you to sort out a trial.
jspark
Re: Buggy Blend - The ultimate floor pan sealer !!!
Postby jspark » Thu Jun 07, 2012 12:08 am
I need some of this!
Can i buy some?
Postby Vduboy » Sun Mar 31, 2013 3:07 pm
Me too! Is this available for sale yet?
Postby Brad » Sun Mar 31, 2013 4:35 pm
Check with Paul at SteelArt he ended up with the mixture and I would say it is tested now
Postby Vduboy » Sun Mar 31, 2013 4:45 pm
Cheers Brad will do mate. Do we know how it went with stone chips etc? It'd have to be easier than por15 to apply!
Postby Brad » Mon Apr 01, 2013 3:37 am
Vduboy wrote:Cheers Brad will do mate. Do we know how it went with stone chips etc? It'd have to be easier than por15 to apply!
Held up well, I kept it in a under body tar spray bottle and when I got back from Fraser it had held up well. I just power washed it and then hit it again good as new. As it is tar based it takes the sane etc in it stride and covers well.
Return to “Product Development”
Users browsing this forum: No registered users and 0 guests
